drsmith7725
I'm create a new account in here. This is best forum site i ever seen and this is my second time in here. Thank you all
Welcome doc! When ya can, start a thread and post some pics.I'm create a new account in here. This is best forum site i ever seen and this is my second time in here. Thank you all
Don’t ask. Don’t tell. [emoji40]I played Dr a time or two!![]()
Thank youWelcome doc! When ya can, start a thread and post some pics.
Hahahahaha! So, videos/pics are out of the question.Don’t ask. Don’t tell. [emoji40]
You're welcome. Glad you like it!I'm create a new account in here. This is best forum site i ever seen and this is my second time in here. Thank you all
PMHahahahaha! So, videos/pics are out of the question.
Haaaa! LOL
Went to MET in NorCal 2 weeks ago.Truck did well on the trail, however once I started to wonder the meadows, I would get stuck instantly. My opinion only, but the falken wildpeak at3 Air down to 15 psi was kind of disappointing .
Good reply, Thank you and I'm enjoying here.Welcome. We try to help people out. We try to have a good time on here. Glad you at least gave us a second try. Most smart people dont . Lol welcome and have fun
YesYou're welcome. Glad you like it!
If the intake looks clean and you can see light through it it’s still working. Shake out the big stuff and run it for a while. Check it later.Did some routine maintenance on the truck as it hit 30k. Fortunately, because of the seepage in the rear diff,Toyota performed the rear diff flush when correcting the seepage. Next on the list was oil change. Pretty basic, used oem filter, mobile1 synthetic 0-20.
However, I did do a little modification to the oil drain plug. Instead of putting back the original drain plug I added a fumoto drain plug. Hopefully this will save me 5-10 minutes in the future and much cleaner drainage of the oil to the pan.View attachment 24506
Changed the cabin air filter to the k&n and just took out and shook my intake filter. Lol let me know if this is a bad idea but it looked pretty clean.
Retorqued and greased uca’s, greased the only nipple on the shaft. Couldn’t find any more is this the only one on the 18’s?
*side note/pics
View attachment 24507 Went to MET in NorCal 2 weeks ago.Truck did well on the trail, however once I started to wonder the meadows, I would get stuck instantly. My opinion only, but the falken wildpeak at3 Air down to 15 psi was kind of disappointing .
Just my buddy and I posingView attachment 24508
Did you get the nipple too?One of the first things I installed on my '17 OR was the Fumoto drain valve......works great......I start draining the crankcase then go to work on the filter. When done with the filter the oil is done and flip the lever up and put the small lock on. Easy and have not noticed any leaks at any time!
