So, I surfed Tacoma Forums for months to include this one and did all the research I could. I’m generally a thorough person, especially when it comes to a big purchase like a camper.  I bought a 3,800lb camper and fully examined the load capacity of my 2019 Tacoma TRD using an estimated tongue weight that was 200lbs more than the dry weight (I did my load out and used 15% to determine). I also chose a slimmer camper (7.5 ft wide and aerodynamic front). I was legal when I towed it the first time (inside my payload and under the max for combined and trailer). I used a properly set up WD hitch with sway control and had a brake controller. Let me tell you, it was not fun. If I could this all over again I would of bought a roof top tent.
1. The truck really, and I didn’t want to believe this, is underpowered. I did all the tricks, ECT mode, rowed my own gears, stayed out of 5th or higher. Honestly I lived in 2nd and 3rd. 40-55 mph, I saw 4th a few times.
2. The brakes/ transmission are not up to the task. I did properly set up my trailer brake controller, but engine braking is non existent and forces you into lots of brake use in the mountains. This stresses the trailer and vehicle brakes. I swear I felt brake fade and I stopped three times to check my trailer brakes for fear of overheating them.
3. Stability is an issue, the width of the truck vs the trailer causes some of it, but I think it’s more the mass of the vehicle pulling something far larger. Aerodynamics, play a role also as you transition from induced drag at low speed to parasitic drag at higher speed unstable air from crosswinds or other vehicles really throws the truck and the trailer around.  I did get trailer sway bad, enough to let off the gas and pinch my brake controller once and probably should have pinched it a couple of other times, but letting off the throttle worked.
Surface area- read up on the Ford Ranger. Ford posts info on the towing ability of the Ranger and they are very specific on surface area. I think the Tacoma is similar enough to use the same principle Ford does. They say anything bigger than 55’ will reduce the towing capacity and performance. I believe I’m about 60’ ish sqr feet on my camper and this may be a major factor.
I just wanted to share this with anyone planning on taking the camper challenge and is on the fence. I now own a sweet camper that was purchased with a Tacoma tow vehicle in mind that I feel unsafe with. I love that Tacoma and if you feel that way too, it’s going to crush you when your stuck with a camper and you have to consider trading in your baby on a bigger whip.
Additionally, you can’t take a camper on much of a trail if you want to boondock. An RTT while it has some down sides is trail ready and a heck of a lot cheaper.
I never post anything. I don’t do social media. So posting this was a big deal for me. I’m doing so humbly and with others in mind.
