JayQQ97
the test subject matter is some brand spanking new OEM brake dust shields for the old '96 Corolla I am restoring, its brushed on from the gallon pail i bot for +80$As for removing cosmoline, you need mineral sprits or similar. I use RP-342 cosmoline thats sprayed on. You can buy rattle cans in black, or the standard amber color.
Pretty easy job actually to apply it once you put the truck on jack stands and remove the tires out of the way. Just suit up in protective clothing you don't want anymore with goggles and have at it.
Fluid flim works, but its lanolin based. As long as you keep on doing it, your good. Once it wash's away your back to square one promoting rust. I've used both, and the cosmoline so far works best for our climate.
i applied in cold November weather, perhaps the cold chill made it look icky? i can snap a pic perhaps to show results better
