JayQQ97
They did not even order the new sealOne of these yota bearing seals is 90$full MSRP
 Just used the old one
 It just so happens that the fonky braking was actually caused by the roasted bearing + wheel hub because all that jiving whilst braking completely stopped... for the time beingA vehicle as old as yours, likely needs new brake fluid, and new lines that connect from the steel ones to the calipers for starters. Even at that age the brake master cylinder/booster can get defective needing replacement. Pads, calipers, rear brake cylinders, and shoes all need to be inspected, or replaced. All these parts are subject to normal wear, and age. They are a major safety system in the truck. Its another reason a 25 year old truck can be a money pit.
I could spend free time sittin around and watch the corn growI don't make a habit of flying either, but I do enjoy other stuff besides just driving, and driving.
 keep dreaming.It's a Toyota
It will run foreverunless rust takes a big superbite
I thought you were just there a couple of weeks ago when you saw the Four Corners Jay.I could spend free time sittin around and watch the corn grow
Once the clutch is replaced and trusty I am looking forward to wheelin' the BQE
The BQE?I thought you were just there a couple of weeks ago when you saw the Four Corners Jay.
Have U been onit?The Brooklyn Queens Expressway?
its a start, but far from complete.I do oil changes radiator coolant and 4wd + Mt fluid on scheduled maintenance
