Rock62
Well....tell you what you could do.
Center the steering wheel as you deem correct. Tie it down so it can't turn or shift.
Lift the front of the truck, then place on a pair of jack stands.
Use two wrenches, adjust those tie rods so you are happy. Put it back on the ground and take it for a ride. Be sure to un-tie the steering wheel before you go.
When you get back, be sure to share how well it tracked and handled. I suspect your test drive will be short.
