Things you do on your taco when you're bored
Play with the useless gauges on my scangauge, like instant mpg, gph of fuel used, horsepower (comical), and when i had the ultragauge i used to watch the header temp skyrocket on freeway onramps.
Dont get me wrong, i love the scangauge but the only gauges i use 99% of the time are the water temp, trans temp (pan), intake temp, and voltage.
Wow! You have a gauge for everything. I'm sure your taco is very modified.
I dont run the ultragauge anymore actually.
Just scangauge which is small and gives 4 virtual gauges.
I do also run a boost gauge, and air fuel ratio gauge for safety.
Intake temps, water temps, trans temps, afr, boost, and voltage are important in my book.
Oil pressure and fuel pressure would be nice as well, but i doubt ill add them.
Its goes fairly well for a truck.
