New Grill Emblem
Bogunn
Alright guys. Got a ridiculously good deal on a new black mesh grill for the 17 TRD Sport. Grill will be delivered Monday so it’ll be on in the next day or two.
I’m going to put the Toyota emblem on there but I can’t decide which one. Suggestions are appreciated. IMG_2997.webpIMG_2987.webpIMG_2988.webp
The chrome one measures 11.2” x 1.6”
The plastic with white letters measures 14 1/8” x 2 3/8”.
Where did you get the grille from
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/191732332558
This is an insert that requires use of the current bezel. If you want to keep the chrome surround on the grill use this. You’ll have to use goop to hold it in place.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/282441634520
This APS insert allows you to ditch the current grill and bezel and it comes with the hardware to install and matches up perfect. This is what I used.
Even though these are cheap if you don’t care to dig around for a while on eBay or online you can usually find a better deal.
Welcome to the forum.
Thanks, I really like the way yours turned out
Appreciate it.
How much was that emblem? That would look good on my 09
If you go with the Toyota emblem on a mesh grille it doesn’t match up well with the OEM screw brackets. I grinded them down flush and used 3M double sided automotive tape to attach the emblem. It was much easier to center it that way. The 3M tape or goop is the best stuff around.
I’ve never used 3M tape on a mesh grille but it holds to everything else so I’ll see how it holds up over time.
