I installed my Kicker door and rear speakers  (access cab) yesterday.  Wow... yep.. WOW...  AND DOUBLE SHAME ON TOYOTA FOR THE CRAP THEY SHIPPED THE TRUCK WITH,  ok..,rant over.
I used the Crutcthfield kits.
No real problems, but  there are a couple of things that might frustrate
- The 6x9 adapter ring holes will not line up on the kicker speakers.  You can get two of them aligned  (left or  right set) then you need to drill two small pilot holes in the adapter for the self-tapping screws to go though.  The hole that did align are too big so with use different screws or put a blob of silicone sealer on the back of the screw thread after assembly.
- The supplied wiring harness adapters aren't perfect.  The small spade connector on the Kicker is extremely tight fit and easy to bend.  Support the terminal when inserting OR.. cut the wire and solder it on.
- The rear speaker adapter requires you to break of all the internal tabs  (easy).
Another point.   The main doors on the Taco are NOT sealed and designed to drip water out the bottom.    My truck has 200  miles on it now, only one overnight rain (when parked) and  it was soaked inside both driver and passenger doors.  The factory POS "speaker" (split!)  has a water shield on top of it to defect drips; the Kickers do not.  The Kicker cones are vastly superior and should be able to take some wet, but I don't like that.    Simply drape a piece of 6 mil plastic over the top of the speaker and secure on the face of the door clamping it with the adapter ring.    For those of you adding sound damping to the door.. it's going to get wet when it rains and will have a heck of a time drying out.  Use  closed cell types if possible.
