whippersnapper02
Negative Nancy
Bummer. So should I just switch to synthetic or stay with normal?
I use synthetic for the added protection because I drive my truck hard. Either one will work fine though.
^^^^^^^^^this is good advice. Most important is the weight and keeping up with oil changes.Either one. It’s up to you. Just make sure it’s the right weight.
I would use synthetic and change it every 5-7k miles depending on how you drive.
We go 8- 10 k , and check every other tank of gas , if you are burning oil , or are Leaking like a White House press secretary !Mobil 1 0W-20 with KN filter here. Have always done 3,000 mile oil changes in past. Think I'll go 5,000 intervals now with the Tacoma.
LOL......I've considered the 8-10K interval.......seems like alot of revolutions on the oil.We go 8- 10 k , and check every other tank of gas , if you are burning oil , or are Leaking like a White House press secretary !
Toyota recommends 3rd gen Tacoma oil be change at 10k with synthetic... But it’s hard to let it go that long when you’re use to 3k and 5k intervals. I changed the oil on my 2017 at 5k Miles but that’s bcause it was at 1 year. I only drive it about 5k Miles a year so I’ll be changing it every 5k Miles or 1 year. I’ll probably use the OEM filter and mobil1 synthetic 0w20 once my 2year free services are up.Mobil 1 0W-20 with KN filter here. Have always done 3,000 mile oil changes in past. Think I'll go 5,000 intervals now with the Tacoma.
Excellente !Toyota recommends 3rd gen Tacoma oil be change at 10k with synthetic... But it’s hard to let it go that long when you’re use to 3k and 5k intervals. I changed the oil on my 2017 at 5k Miles but that’s bcause it was at 1 year. I only drive it about 5k Miles a year so I’ll be changing it every 5k Miles or 1 year. I’ll probably use the OEM filter and mobil1 synthetic 0w20 once my 2year free services are up.
