Bojangles
Im betting toyota doesnt make any fluid.... therefore i bet someone else makes 75 85I use Redline 75w85 gl5 for the diffs its the only company other than oem Toyota that makes this weight at a somewhat reasonable cost
Redline does.Im betting toyota doesnt make any fluid.... therefore i bet someone else makes 75 85
https://www.amazon.com/Toyota-Genuine-Fluid-08885-02506-Differential/dp/B004SL9HP6 I can get the Redline 75w85 gl5 for $16 a quart, probably should just use the 75w90 gl5 but im trying to stick with Toyotas recommendations on oils. I use the 75w85 in the rear diff only and use Walmart super tech 75w90 in the transfer and front diff this offsets the total cost a little for a 30k maintainence. since the trucks a daily driver I want the best MPGs so using the lighter oil in the rear might help some, if I towed or hauled heavy loads a lot I would use the 75w90 a little thicker oil.Im betting toyota doesnt make any fluid.... therefore i bet someone else makes 75 85
best price is Redline 75w85 gl5 I could find, got it thru Walmart.com online $16 a quart with free shippingHell, delco makes it too
I thought I saw a reference to this somewhere, but cannot find it (on mobile)... I'm trying to figure out what to use in my diff (Prerunner with electric locking diff). What exactly is an "imposter"?Mobil 1 75-90 synthetic . no LSD additive as mine is an imposter..
I just used the word "imposter" because mine is not an actual limited slip. It is simulated by the rear brakes. I don't know much about the locking diffs and don't want to give you bad info. @whippersnapper02 has the Off road taco.I thought I saw a reference to this somewhere, but cannot find it (on mobile)... I'm trying to figure out what to use in my diff (Prerunner with electric locking diff). What exactly is an "imposter"?
Thanks! I've been really spoiled with mine (Read: haven't had to touch it and therefore am ignorant), and am trying to get the lingo down!I just used the word "imposter" because mine is not an actual limited slip. It is simulated by the rear brakes. I don't know much about the locking diffs and don't want to give you bad info. @whippersnapper02 has the Off road taco.
What year is it? 2009 was the first year of the fake limited slip diff.Thanks! I've been really spoiled with mine (Read: haven't had to touch it and therefore am ignorant), and am trying to get the lingo down!
It's an '05 Off Road.What year is it? 2009 was the first year of the fake limited slip diff.
You will need the LSD additive. Even if the bottle says it has it in it. Still add itIt's an '05 Off Road.
Excellent, thanks for the info! The next month or so will be quite interesting LOL.You will need the LSD additive. Even if the bottle says it has it in it. Still add it
Remove the fill plug first then the drain plug. If you drain it then can't fill it your in trouble.Excellent, thanks for the info! The next month or so will be quite interesting LOL.
LOLOLOL thanks, that would... NOT be pleasant!Remove the fill plug first then the drain plug. If you drain it then can't fill it your in trouble.
U dont need any additive on an offroad.I thought I saw a reference to this somewhere, but cannot find it (on mobile)... I'm trying to figure out what to use in my diff (Prerunner with electric locking diff). What exactly is an "imposter"?
Incorrect.... offroad needs no additive, it is not limited slip.You will need the LSD additive. Even if the bottle says it has it in it. Still add it
Well I suppose your correct jangleyIncorrect.... offroad needs no additive, it is not limited slip.
