Has anyone put 37 inch tires or bigger?
35's on a Tacoma alone is just stupid Af. You will have the slowest truck on the planet, unless you have a Trd supercharger. Stick to 33's they're just better for Tacomas.
Nothing is stupid if you have the money and build it right. Some change the gear ratio, some don't. I don't buy Tacomas to racing anyone. My 7700 lbs Duramax with 800 rear wheel HP will beat most tuner cars.
Well the only reason I say it'd be stupid is becuase if someone tried lifting a trick and slapping on 37's. Your asking for problems if you do that.
There is a ****load of people who run 35s on Tacomas.. You don't even need the supercharger, just a regear..
Yes that's reuse but the reason I say put a supercharger on is becuase your truck will be slow as hella with a stock motor with 35's... That's why I stick to 33's
