JayQQ97
MW surVivor ... clutched. 364k on the 0D0
Maybe drill them out?Only way thats going to come loose is with heat, and a torx socket using a ratchet tool.
High torqued from the yota factory
One of the 3 already started stripping
Its why you should of immediately put the heat to them and used a torx and ratchet on them. Sometimes it helps hitting them with a hammer after soaking them for awhile with pb blaster. Drilling is always my last resort.Maybe drill them out?
One of the 3 already started stripping![]()
Forgot to add if your handy with a welder, you could weld another bolt to those stripped heads, and try to break them loose.
https://www.tooldiscounter.com/prod...xdQERylVS9L6Ca7OfczETqTwQY3FRIJEaAqtoEALw_wcBOver 900$ for this after fees
867$ before fees
Could it pay for itself over a few short years
Is there better equipment out there for suspension work?
https://www.amazon.com/OEMTOOLS-24860-Operated-Spring-Compressor/dp/B00X9LZMS2
Yeah you could, i didn't know exactly what your working on.i was warned somewhere about heating a knuckle and doing damage
Not I nor my nephew LOLOffset box wrench's? Thought everyone has some of those.
