the big LBJ...
You'll know it when you have a ball joint failure like in the video, plus if an everyday driver, you got to know when to hold them, and when to fold them when it comes to those old trucks, or they will nickel, and dime you till your broke, or on foot.:(
there was a recall for my 2004 tacoma to replace the lower ball joints, maybe investigation into that you may get them replaced by Yota under a recall if your year matches up, might be worth looking into it
I think toyota would laugh their ass off if you tried to ask for a free recall like that for a truck older than 12 years.
AI Overview
Learn more
Technically, there is no time limiton getting a Toyota recall repaired; car recalls do not expire, meaning you can get the issue fixed even years after the recall was announced, as long as the part is still available and the dealership can access the recall information.
Key points to remember:
  • No expiration date:
    While there's no set time limit, it's crucial to address recalls as soon as possible to ensure your safety.
  • Dealer responsibility:
    Most Toyota dealerships should still honor recalls even if your car is older, and will perform the repair free of charge.
  • Contact Toyota:
    If you encounter any issues getting a recall repair done, contact Toyota directly to clarify your eligibility.
AI Overview
Learn more
  • Contact Toyota:
BS, I doubt if thats true....many recalls on those trucks have long expired. For one try getting a new frame if your 20 year old one had rotted out. I have a fuel pump recall on my truck, but it's not forever. As long as the original one still functions fine their're not going to replace it.
I would think rotted out frames, and faulty fuel pumps are safety recalls. Toyota might inspect some of that stuff, but if ok, they are not going to replace it....and I don't even think it would apply to a 25 year old vehicle.
Heck if the manufacture claims that part is no longer made for your 15-25 year old truck, your sol, safety recall, or not.
Perhaps there was a different design those years?
They have both been changed once and one side it's been twice now with the roached bearing the dumbazz brake shop didn't spot when it had sketchy braking issues
I had a 2004 TRD tacoma 4x4 had the LBJ's replaced(recall) by Toyota never had a problem with them made 200k miles +++ what ever brand they used worked flawlessly for that time
I had a frame recall on my 2001 tundra...it had free replacement within 10 years. I took the recall to the dealer several years later before the offer expired. They did their multi-point inspection only replacing the spare tire cross member, saying the rest of the frame was fine. I still questioned why the entire frame wasn't changed if the tsb I got through the mail stated it would be. They said it's up to the dealers discretion.... safety recall, or not. Its basically the same for this tsb fuel pump recall on my gen3 tacoma.
Do what Charlie does here....if it ain't broke don't fix it. This guy must have a horseshoe up his ass. He'll always get the most from everything, yet comes out smelling like he just took a shower.
