OR17TRD
Didn’t want you to hate to think a third gen had drivetrain issues on Christmas.Thanks for the correction. [emoji6]
Did you ever figure out the braking vibrations? Maybe this noise has something to do with that?
Sounds like an actuator is not engaging fully. Does it speed up and slow down with your speed? Also can you still change your AC/Heat setting from floor, dash, combo, and defrost? It may sound weird but if there is no change in the vents it is likely that fluid leaked in to the vacuum system.
$0.10 zip tie fix it?Yeah it was just a cable hitting the transfer case Hahahaha
At least it wasn’t a big issue. It sounded terrible. Lol.
Now you are.Haha yay! Wasn't happy [emoji4]
But then the horn stops working!! Hahahaha
There ya go. Saved you a ton of money. That should have you fixed for about $5.
And the best part of using the air horn is that your passenger side seat will be stained like that drivers seat your giving away because your passenger will crap their pants if you hit it in the cab. Lol.
Hahahahaha. Oh Bogunn! You got jokes!! An air horn would scare the next door neighbors
Gross.Just trying to save you some cash and make your seats match. Lol.
