toywoodsguy82
Your thoughts or pros and cons with iridium spark plugs?? Some say it’s not worth it and some actually say it LOWERS gas mileage.
4.0L with 112k on it.
Unless you have the hood scoop. LolThe only benefit is they last longer. They don't increase mileage.
And a snorkel and leave the M61 sticker on.Unless you have the hood scoop. Lol
He said lowers mpg.The only benefit is they last longer. They don't increase mileage.
He said lowers mpg.
I've heard this too.Some owners report their trucks dont run well with em (v6).
I heard theres a huge underground fire in Mo, next to some toxic waste. I assume housing/trailers are cheap?I've heard this too.
Shoulda seen the messege in the snorkelI’ve heard stuff about you. I actually read stuff about you on the bathroom wall. @Bojangles wrote some pretty nasty stuff about you and your snorkel.
[emoji33]REPORTED! @Bojangles too.Don’t mention what @kp.taco does at the glory hole...... I mean the snorkel hole.
Well, I just replaced some Iridium plugs with stock Denso this past weekend. I found my old maintenance sheet, and it appears that I hadn't replaced them in 75k [emoji51] . While they might look better than copper plugs would at 75k, the truck did run a little rough, so if they do last longer, I'd be curious as to the real definition of "last longer". Stock plug gapped to .040", while the old Iridium gap had eroded to .070" (yowsa!):Your thoughts or pros and cons with iridium spark plugs?? Some say it’s not worth it and some actually say it LOWERS gas mileage.
Good note to self HahaWell, I just replaced some Iridium plugs with stock Denso this past weekend. I found my old maintenance sheet, and it appears that I hadn't replaced them in 75k [emoji51] . While they might look better than copper plugs would at 75k, the truck did run a little rough, so if they do last longer, I'd be curious as to the real definition of "last longer". Stock plug gapped to .040", while the old Iridium gap had eroded to .070" (yowsa!):
Note to self: don't put off replacing the plugs until the truck runs roughly! HahahaView attachment 17105
Purrs like a kitten now though!Good note to self Haha
