Don't you have the threaded holes in your drums that used with a bolt that size to pop them loose?Some anti seize
Awww no, did I put that stuff in the spots??Don't you have the threaded holes in your drums that used with a bolt that size to pop them loose?
Have you tried steel wool or a wire brush????
good greif......how much dust do you have????
I just wear a face mask, and use my air compressor to blow away any brake dust. I use brake cleen pretty sparingly. That stuff is nasty.on brake shoe dust?
Off-topic...@JayQQ97
Just as a thought......Try a stiff brush coupled with a shop vac to collect the loose stuff. Then use the brake clean.
It'll be better for your health, the environment, your wallet and you won't risk damaging other parts (ie paint)
A case of that stuff can't be easy on the wallet.
